ricoh mpc3000 add toner reset code
  • BATA
    • Mar 2012
    • 27
    hello guys, my customer has refilled toner without adding the chip , how can i reset the toner message from the sp mode for ricoh mpc3000 , thank you for urgent replying
  • JustManuals
    • Jan 2006
    • 9838
    Re: ricoh mpc3000 add toner reset code
    Paul@justmanuals.com
    • lar57
      SP3045- enables/disables the toner alert display on the LCD. Worth a try.
      • sandmanmac
        • 3981
        That's going to be the least of their problems very soon
        • collme
          Ricoh tech
          • 221
          That chip is not just for the display, it contains quite a lot of info including ser no of the bottle and lot no, so any problems that are now going to appear with toner pumps and blockages will not be covered by any maintainace agreement and should you need a Ricoh support visit he will just walk away from the machine with none oem toner having been fitted. All toner bottle ser no are logged so Ricoh can see if none oem supplies have ever been used.
          • Davven
            • Jun 2009
            • 21
            SP 3045 is for shorter usage only, if a toner pump breaks you probably can use it for some day.
            But if you keep using it longer period of time you will break the developer in the devbox.
            Thats my opinon, I have tried that before.
            • Llama God
              • Mar 2009
              • 1353
              Don't do this.
              • Llama God
                • Mar 2009
                • 1353
                Definitely don't do this.
                • Eric1968
                  • 2458
                  x2
                  Unless you like replacing development units...
                  • sandmanmac
                    • 3981
                    If it's the "independent supplier" message you're talking about, then set SP5051 (refill toner detection display) to "Off"
