request time out
  • margic brian
    • Jul 2012
    • 97
    [Misc] request time out
    my client has an mp171 she claims she cant print and scan her documents, so i tried pinging the machine instead i get a message "request time out " what could be the problem your help will be highly appreciated thanks
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: request time out
    Is the machine set to DHCP or static IP? Is the IP on the same subnet as the PC(s)? Are you connecting to it's IP address or host name?
    • sandmanmac
      • 3981
      You haven't even told us what you've done or checked....
      Is the NIC light on? NIC enabled?
      Maybe they installed a new router?
      Maybe the port is defective in the router?
      Maybe the cable is unplugged?
      Maybe the cable is defective?
      Maybe the IP address got changed in the machine?
      How about a little more info?\
      There's dozens of reasons when we have no details, and you've given us nothing to work with!
      • Ollie1981
        Toner Monkey
        • Mar 2008
        • 417
          • 23006
          Originally posted by Ollie1981
          First thing to check, is the network cable plugged in? ...
          Same in our office. "Won't print!"
          Is it plugged in? Is it turned on? Is there a network cable? Is that cable attached to something?
          (Somebody had disconnected the network cable to plug in a network phone.)
          • Llama God
            • Mar 2009
            • 1353
            Yes, it's Brian again. What a surprise.
