Ricoh Afficio 3235c black toner error on multiple machines
  • copy.eva
    • Jun 2012
    • 33
    The machine is performing loading toner all the time. This is happening on 3 machines from the same type with original toner. We tried changing the toner pump, but no effect. Any advice would be helpfull.
  • sandmanmac
    • 3983
    Re: Ricoh Afficio 3235c black toner error on multiple machines
    Are the hoses clear?
    If so then I'd do Dev Clutch, and /or dev unit
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • CableGuy
        Impulse Drive Engineer
        • 417
        You also need to clean the sensor that looks at the toner leaving the hopper, just above the pipe....they get fouled up with toner
        • kannuki2
          • Feb 2012
          • 398
          I would inspect the tube as cableguy said. Also, I would try to do a force toner supply SP 2207 to see if the toner supply clutch is working. You will see zebra-like white streaks across the pages if development clutch is defective.
