The machine is performing loading toner all the time. This is happening on 3 machines from the same type with original toner. We tried changing the toner pump, but no effect. Any advice would be helpfull.
Ricoh Afficio 3235c black toner error on multiple machines
Re: Ricoh Afficio 3235c black toner error on multiple machines
Are the hoses clear?
If so then I'd do Dev Clutch, and /or dev unit -
Paul@justmanuals.com
I would inspect the tube as cableguy said. Also, I would try to do a force toner supply SP 2207 to see if the toner supply clutch is working. You will see zebra-like white streaks across the pages if development clutch is defective.Comment
