how to set fax receive tone on ricoh MF2022 ?
  • stupidkiller
    • Oct 2011
    • 57
    suppose is one ringtone to get receive the incoming fax
    but how to change the ringtone to 5 sound ?
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: how to set fax receive tone on ricoh MF2022 ?
    Are you wanting to change the volume of the ring, or the number of rings to answer?????????????
    Mystic Crystal Revelations
    • stupidkiller
      • Oct 2011
      • 57
      number of ring to answer
      thanks for reply
      • Tonerbomb
        • Feb 2005
        • 2589
        thanks for reply
        That would be NCU parameter 01 on the typical Ricoh fax option. It would show Value of 1 you can change to what ever you need.
        • sandmanmac
          • 3983
          You could also search the word 'rings' in any fax manual
          • stupidkiller
            • Oct 2011
            • 57
            do u mean NCU parameter inside fax sp mode?but i saw it got G3-1 and G3-2,may i know which one?
            • stupidkiller
              • Oct 2011
              • 57
              i got the manual but i cant find anything regarding ring on the manual,tats bad
              • Iowatech
                Not a service manager
                • 3930
                In the fax option portion of the manual, it is in the "bit switches" topic. Make sure to follow the instructions there, otherwise bad things could happen.
                Hope that helps.
                • stupidkiller
                  • Oct 2011
                  • 57
                  Hope that helps.
                  i have read all the bit swithes in th manual but i cant anything is mention about the ring
                  can u please let me know more detail?thanks
                  • sandmanmac
                    • 3983
                    Really? I just did exactly what I suggested to you earlier, and searched "rings" in the Aficio 2027 service manual (fax section), and found EXACTLY what you're asking for.
                    Hint: It's SP2-xxx-x
                    That's all you're getting from me
                    • Iowatech
                      • 3930
                      Sounds like you are using the wrong manual, you might try downloading the correct user manuals from Ricoh's website.
                      If that doesn't work, try this:
                      • stupidkiller
                        • Oct 2011
                        • 57
                        ok i found it sp2-103-6 its currently 0 i try to change it to 5 but seems no effect,look same my phone ring 1 sound n the fax receive directly,n i using auto reception now.
                        can u help me agan?thanks =)
