SC324 Development on MP4001/5001
  • kannuki2
    • Feb 2012
    • 398
    I understand that the sc324 is caused due to the drive bearing on the development unit but has anyone find an alternative bearing part number to replace it? modbearingpic.JPG
  • pbbsinc
    • Nov 2005
    • 92
    Re: SC324 Development on MP4001/5001
    I'd love to find an answer to this... Seems a shame to spend hundreds of dollars on a DV unit just because a 5 dollar bearing is locked up.
    I have, on several occasions, taken the bearing out, pulled the seals off, cleaned & re-greased it, and re-installed it. It avoids a down customer & works for 100k+, but I would like to have spares.
    I'll research it & post a solution if I find one.
    • jermyth
      Riso dude
      • Mar 2011
      • 440
      I recently ran into this and found two Ricoh bearings that are the same size, just different seal, AE030022 & AE030027. Lower fuser bearings.
      But if you want to find a bearing supplier the number is 6901RU for actual bearing.
      • pbbsinc
        • Nov 2005
        • 92
        Great info... Thanks
        I ordered 10 bearings from a company called VXB Bearing yesterday. Same PN you reference above (6901-2RS). They cost me less than 5 bucks ea. They look like they have the same rubber side seals as the ones in the unit. We'll see how they work.
        • Athlontini
          • Jun 2012
          • 269
          Same here. Shoot some light lubricant down in there and it frees right up.
          However, the only time I see this happen is on dev units with >500k on them that probably ought to be replaced soon anyway...
          • Michael McCord
            • Jul 2014
            • 5
            Originally posted by kannuki2
            I understand that the sc324 is caused due to the drive bearing on the development unit but has anyone find an alternative bearing part number to replace it? [ATTACH=CONFIG]18304[/ATTACH]
            Im in the same ball park. I know someone has posted the part number for that bearing.
            • tjvincent
              • 280
              6901-2rs, you will find them on Ebay
              • francisco
                • Nov 2009
                • 168
                i use AE030022 and until now i have no issues.
                • Wild Bill
                  • Jul 2005
                  • 774
                  I've been replacing these with mixed results. If the V-Ring seal is damaged or distorted it will quickly fill the bearing with developer again.
                  Has anyone found a replacement for these seals? Kind of strange to supply a new bearing but forget seals. Sharp has had v-rings for years but nothing this size.
                  PN for the replacement bearing is B004 3059 Service Bulletin D129/D130 - 015
                  This is for 4002 It should be the same.
                  Izzy
                  • Dusmccor
                    • Jan 2012
                    • 8
                    Good point Wild Bill. I've wondered about the seals myself. While running through a pm yesterday, I started wondered if maybe an answer would be adding a spacer of some sort between the auger and v-ring to help keep the seal compressed.
                    Anyone have any thoughts.....?
