SC 670 MP8001
  • katash
    • May 2010
    • 221
    [Error Code] SC 670 MP8001
    Hi guys,
    i need your input and help!
    the above MFP gives a silent sc670 whenever the copier is not operating or goes to energy saver,
    indicates restarting then the usual reboot process.i have updated both system/copy and engine firmware but the fault is re-occur rent,any fresh ideas would be very valuable,
    kind regards.
  • Max
    • Oct 2011
    • 561
    Re: SC 670 MP8001
    Re fit every connector on bicu/controller 1st see if that helps
    • Zeldaman
      • Mar 2011
      • 946
      Re: SC 670 MP8001
      Hi there!
      You can also try to format the HDD.
      Greetings...
      • kannuki2
        • Feb 2012
        • 398
        Re: SC 670 MP8001
        Yup I would backup the address book before start the SP5832-1. Also, 'lock print' jobs can cause this problem too. I would use SP5801-4 to free up the memory application in the machine.
        • katash
          • May 2010
          • 221
          Re: SC 670 MP8001
          thanks for the response,did check the connectors,will see about the hard disk formatting and will let you know,
