How to connect a counter meter on a RICOH MPC 2500
  • pukiro
    • Feb 2011
    • 59
    hi
    do anyone know where to connect a counter meter to a mpc 2500?
    p.s. need to count b/w copies only
    thanks
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: How to connect a counter meter on a RICOH MPC 2500
    Like the one that built into the machine already? You need to enter Service Mode and under Copy SP/System SP -> Mode set the accounting counter to 1.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      Paul@justmanuals.com
      • TonerMunkeh
        Professional Moron
        • 3865
        I think he means an external counter. It needs connecting to the optional key counter interface on the machine, if it has one, then key counter management enabling in user tools to control it.
        Hit it.
        • jonhiker
          • 661
          you also have to enable it in SP modes
          • sandmanmac
            • 3979
            Originally posted by pukiro
            hi
            thanks
            Never done it, but if I had to, I'd simply follow the step-by-step instructions in the service manual.
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              For an external counter/coin op/card reader you need optional counter interface type A (413012). Had to use one of these to set up a coin op once.
              Mystic Crystal Revelations
              • oldschool
                • Mar 2007
                • 245
                Are you just looking to count the copies made or are you looking for a way to stop people from making copies unless they have a plug in counter?
                The type A kit will tell you the difference between color and black and white. The issue you may run into is the color signal is 5VDC and is either high or low depending on the copy type but the count is a 24 Volt pulse that happens at every paper feed regardless of copy type.
                Jamex Tech Support: Saving the world one phone call at a time.
