MP161F
  • rthonpm
    • Aug 2007
    • 2854
    Re: MP161F
    Have you tried turning off ECM? Fax SP 1-104-002, change bit 0 to '0'. ECM usually is very picky about working with anything outside of a perfectly configured phone line. For that reason I turn it off on every machine I can lay my hands on.
    Also, if you run the fax error report in the fax SP, do any error codes show when the TX fails? That may give some idea of more SPs to change.
