Hard Drive Replacement
  • bunnthebody
    • Oct 2008
    • 38
    [Electrical] Hard Drive Replacement
    I have an MPC2800 that has a bad hard drive. Fax is stuck with loading on the display. I cannot print or scan and I cannot enter SP mode. There are no error codes. If I disconnect the drive, I can enter SP mode, fax and print. Is there any way to save the address book so I can install it later. Thanks, Roger.
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: Hard Drive Replacement
    Will it let you print the address book, even though print jobs don't work?
    • Athlontini
      • Jun 2012
      • 269
      SP5846-051 should let you copy the address book from the HDD to an SD card.
      • kannuki2
        • Feb 2012
        • 398
        Best method is to use the WIM to backup the address book even the machine stall.
        You can download the Smart device monitor for admin from Welcome to Downloads.
