MPC3500 Jam 019
  • mrfuser
    • 1617
    MPC3500 Jam 019
    Ok, we get a JAM 019, clear the paper from fuser entrance and then it runs just fine. If we leave it for a bit then come back to make a copy it then jams again J019. Clear it and runs fine until we leave it again.
    Any thoughts why?
    Kelly
  • sandmanmac
    • 3981
    Re: MPC3500 Jam 019
    So it seems you haven't actually tried anything yet?
    1 way bearing gear on fuser slipping? Exit sensor? Damage to fuser rollers causing improper rotation?
    • mrfuser
      • 1617
      Re: MPC3500 Jam 019
      Yes we pulled fuser apart and all looked fine. Again, it only happens when it has been idle and we run a page. After first clear and run more consecutively it runs fine until idle again for a bit.
      Kelly
      • sandmanmac
        • 3981
        Re: MPC3500 Jam 019
        Kelly
        No harm in trying my other suggestions then-particularly the gear
        • mrfuser
          • 1617
          Re: MPC3500 Jam 019
          Exactly where is that gear you speak of?
          Kelly
          • sandmanmac
            • 3981
            Re: MPC3500 Jam 019
            Kelly
            If you've actually had one apart, it really is pretty hard to miss the big gear with the 1-way bearing in it
            • flo
              Engineer
              • Mar 2009
              • 44
              Re: MPC3500 Jam 019
              Any thoughts why?
              Kelly
              It is the Stripper Plate from press roller its stll go hanging when heat come up and paper go between and stay there J019
              • Debs1964
                • Oct 2010
                • 1693
                Re: MPC3500 Jam 019
                Bushings in exit assembly, strip it down, clean and regrease the bushings
                There are 10 types of people in this world, those who understand binary maths and those who don't
                • kannuki2
                  • Feb 2012
                  • 398
                  Re: MPC3500 Jam 019
                  The exit sensor (input check SP5803-65) is really flaky on this model and clean the one way gear real good.
