please whait ????
  • andreasd
    • Apr 2012
    • 8
    [Dead] please whait ????
    I have a Ricoh MP 4000 The machine starts and stick In the indication PLEASE WAIT
    I changed the controller board but nothing happened.
    someone maybe knows something about this problem ??
    I would appreciate some help on this problem
    because it plagues me a long time now
  • Bantams
    • Jun 2012
    • 603
    Re: please whait ????
    usually its the HDD unplug the HDD and see what happens then plug it back in and try to format it.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • andreasd
        • Apr 2012
        • 8
        thanks ! but the machine is the model MP 4000B without HDD have just one RAM and one SD card.
        • andreasd
          • Apr 2012
          • 8
          • copiman
            • Sep 2011
            • 861
            Bantams is right. Just unplug the HDD and power on the copier. It will probably go ready. If so power down and plug in the HDD, power on the copier. As Bantams stated, reformat the HDD. Keep in mind you will loose the address book when you reformat, so back it up before doing it. If you end up having to replace the HDD, you can leave it unplugged until you return with one. You loose some functionality, but they will not be completely down. By the way, this is common with Ricohs. By the way, Born in Verdun. Good luck.
            • collme
              Ricoh tech
              • 221
              I thought all MP4000B come with a HDD, it is the extra memory that is an optional extra needed if the enhanced print option is installed. HDD is standard I am sure.
              • Debs1964
                • Oct 2010
                • 1693
                I thought so too, but I've just looked it up, it is standard with the MP4000, but an option on the MP4000B
                There are 10 types of people in this world, those who understand binary maths and those who don't
                • collme
                  Ricoh tech
                  • 221
                  Oh i stand corrected, Good spot Debs. I am surprised by that. Had a "please wait on an MP2550 russian C5 which ended up being the display control board but only had it on an MP4000B when HDD or control board failed. I have a shed load of these in our biggest customer as well so will be interested if a solution is found.
                  • copiman
                    • Sep 2011
                    • 861
                    D009.docThought I would throw this out there.
                    • andreasd
                      • Apr 2012
                      • 8
                      Originally posted by copiman
                      [ATTACH]18658[/ATTACH]Thought I would throw this out there.
                      Thanks a loot copiman . very useful that you sent to me. The machines Ricoh MP 4000/5000 is for the garbage.
                      regards
                      Andreas
