MP C2500 Network Faxing
  • iscott
    • Mar 2010
    • 344
    Question is can you have the fax attachment sent as a PDF instead as a Tiff?
  • Debs1964
    • Oct 2010
    • 1693
    Re: MP C2500 Network Faxing
    Yes, go to fax features, initial settings, parameter settings, bit switch 21, change 3 to ON
    There are 10 types of people in this world, those who understand binary maths and those who don't
    • Debs1964
      • Oct 2010
      • 1693
      Originally posted by mikedci
      According to tb MP C2500's don't support it.
      You may be right, I can't remember which models I've set it up on. I have a notebook with useful info in, and that is one of the instructions I have written down
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Mikedci is right - it can't be changed to PDF.
        A lot of these smaller machines, as well as some of the older larger ones won't support it.
        The deceiving part is that the switch (that Deb mentioned) is there, but has no effect.
        Been there on this one, no fun - especially when the salesman promised the customer it will work.
        • sandmanmac
          • 3983
          The switch does work, but only faxes forwarded to a folder can be sent as PDF and not to email. Now that's the part I don't get.
          I think it's basically machines 2008 and newer that PDF is no problem on anything
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            True, that is correct - folder is effected. I should have made note of that in my post - I guess I was focused on the email part.
            I had a (very ugly) circumstance where the customer HAD to have it PDF, as they had the need to read the fax on a smartphone, and PDF was required.
            Even though that was some time ago, it still sticks in my head.
            Of course, the salesman said "No problem, we can do that!".
            • kannuki2
              • Feb 2012
              • 398
              try using WIM and it should be under fascimile in the configuration there is button call parameter setting that change to pdf.
              • sandmanmac
                • 3983
                Sorry, but we've covered this already. This model is NOT capable of forwarding to email in PDF. Period.
