R-1035
  • tcypy1961
    • 773
    R-1035
    Having an intermittent misfeeding problem mainly on multiple copy runs; when it starts it can be as few as 2 copies; can't get it to stop on single runs. Paper stops as it enters the switch-back/exit unit. I'm thinking end sensor; I brought one out but apparently is worse off than one in machine. Am I on the right track???
    Thanks!!!
    • 22930
    Re: R-1035
    What jam codes? =^..^=
    • Athlontini
      • Jun 2012
      • 269
      Re: R-1035
      Are all the paper tray sizes set correctly, both on the dials and in User Tools?
      • Llama God
        • Mar 2009
        • 1353
        Re: R-1035
        The interchange unit has a gate in it which starts to stick on the muffling pads. You'll have to take the whole scanner unit off, take out the interchange unit and remove the pads.
        • kyoceran
          • 100
          Re: R-1035
          fuser exit sensor
          • Llama God
            • Mar 2009
            • 1353
            Re: R-1035
            Originally posted by kyoceran
            fuser exit sensor
            That too, it's on the black guide on the side door when you open it if that makes it easier to find.
            • kannuki2
              • Feb 2012
              • 398
              Re: R-1035
              this is the sticky pad lamma was talking about.
