aficio 650
  • vargue
    • Oct 2011
    • 404
    [Dead] aficio 650
    today i met machine when i copying it's make just scan .although i make counter image it's working ... no problem my head not grasp what is that threat. i didn't met this threat before .with knowledge that i changed yesterday .drum myler . and drum brush.
  • sandmanmac
    • 3981
    Re: aficio 650
    Since you say that you worked on the drum unit yesterday, it seems related to that area. Here's what I found:
    charge grid shorting out~clean or replace
    drum unit not set, check SP 5 803 number 14 bit 1 should be 0 at ready
    Install M level firmware or higher
    make sure finisher is grounded
    perform RAM clear
    [copying is displayed - no operation] - charge grid shorting out-clean or replace
    [copying is displayed - no operation] - make sure finisher is grounded
    [copying is displayed - no operation] - perform RAM clear
    Replace PCU unit
    • JustManuals
      • Jan 2006
      • 9838
      Re: aficio 650
      Paul@justmanuals.com
      • Vollegaaz
        • 73
        Re: aficio 650
        try cleaning/adjust the drum-unit connector, bad contact can cause zero reading from the Drum-potential sensor and the machine won't start, you can continue scanning but nothing happens.
        • vargue
          • Oct 2011
          • 404
          Re: aficio 650
          thanks shapes sandmanmac and vollegaas it's bad drum conducted.it's now working .after that one of previous technician left switch num3.i make it down .collection of wrench signal revealed.i keep it working on it.thanks guies
