I have an aficio 2018 an I want to scan documents but the display says that you need to enter password, I don't know what it is. What can I do to reset it or what is the password default? thanks.
How can I reset password administrator ricoh aficio 2018?
Tags: None
Re: How can I reset password administrator ricoh aficio 2018?
Have a look around. Password reset/ disabling for almost all models has been discussed in this forum ad nauseum -
If you still want to change the copiers own credentials, you can (if I remember correctly for this model) use "admin" and "password" as the login credentials, if I am wrong use the newer: "admin" and leave password empty.Comment
user tools
system settings
key operator tools
user code management
scanner
offComment
