MP 2550 with DF3030 dog ears originals when scanning
  • copyaction
    • Oct 2007
    • 991
    Yes I have seen the other posts regarding this problem but I still have a couple of questions.
    On the left hinge which springs need stretching and or washers added?
    If that doesn't work, does the entire hinge assy get replaced or just the springs?
    Before I take off way more stuff than needs to, how does the hinge come out?
  • sandmanmac
    • 3981
    Re: MP 2550 with DF3030 dog ears originals when scanning
    So, you haven't actually tried ANY of the solutions that GENERALLY ALWAYS WORK? You're actually wondering how to proceed if none of them do? Is that correct?
    • copyaction
      • Oct 2007
      • 991
      No, I tried to get the left hinge out but was unable.
      I just wanted to see if I was going about it correctly or if there is a simpler way to get it out that I am not seeing.
      I removed about 12 screws, the plastic wire guide above the hinge and the drive motor to the right of the hinge looking at it from the rear.
      That is why I am wondering does it come all the way out and does the whole hinge get replaced, or like someone in a previous post said replace the springs?
      So I do want to try the solutions that generally work but I wasn't clear which springs get stretched and how to acces them since I couldn't get the hinge out.
      Sorry I was working on this late tonight and probably not explaining myself really clear.
      • rsyarcia
        Hair Straightener Tech
        • 711
        On top of each springs put 2 to 3 washers, expanding the spring is hard using a washer is easier and it
        will not affect the quality of the spring.
        Nobody is perfect..
        • copyaction
          • Oct 2007
          • 991
          OK thanks, but how do I get to the springs to put the 2 to 3 washers on top?
          • The Good Old Days
            • Jul 2010
            • 6
            I take the spring and shoulder screw and toss them. Find a screw with a short shaft and tighten it down. Be sure the screw does not hit the horizontal hinge pin
            • rsyarcia
              • 711
              please do your part! we can't tell you step by step coz we are all technicians. we have to use our head!
              Nobody is perfect..
              • copyaction
                • Oct 2007
                • 991
                thanks, now I know which springs we are talking about.
                worked great, thanks to all for their help!
                • kannuki2
                  • Feb 2012
                  • 398
                  To clarify what they are talking about... here's the picture of it
                  checked the left hinge screw circled in red and replace it with a shorter screw like above mention.
                  • The Good Old Days
                    • Jul 2010
                    • 6
                    Yes but be sure the screw dose not hit #11 the horizontal shaft.
                    • Larryo
                      • Jul 2012
                      • 18
                      I just remove the document feeder and LIGHTLY push straight down on the left side of the frame right where the hinge mounts with the flat of my hand. It works just as good as all the hinge modifications/replacemets (which are expensive) and it takes about two minutes start to finish. The key is LIGHTLY push down. It only has to move a teeny bit.
                      • rsyarcia
                        • 711
                        we did what you have done that's why when this "lightly pushing that you are saying" doesnt work we recommend to put more tension...
                        Nobody is perfect..
                        • logrady2331
                          • Feb 2011
                          • 301
                          Do whatever you think is best, I'm just telling you waht works for us and has worked since the dawn of copiers. (Last part is a joke, I've only got twenty seven years of expereince) YOu have to put some pressure on it but don't go crazy is what I was trying to say. We have never replaced a hinge unless it physically breaks.
                          • rsyarcia
                            • 711
                            We didn't replace any hinge and the modification is not expensive. We have technicians with 32 years of experience but i never heard them telling about that.
                            Nobody is perfect..
                            • redneckstylin
                              • Sep 2011
                              • 173
                              ive always adjusted the 2 springs under the screws on top of hinge left side just pull a bit on the coil nice and even and voila no more corner flipping
