MPc3500 SC 400
  • MitchD
    • Oct 2012
    • 164
    MPc3500 SC 400
    I have a MPc3500 that throws a SC 400 and will not let my tech run process control, toner add, and will not clear the code. My tech pulled and cleaned all drum units and ID Sensor board.
    Any ideas?
    Firmware is all current and the code just appeared out of the blue
    "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: MPc3500 SC 400
    Clean the ID sensor, make sure you remove all toner on the sensors as well as the frame around the sensors. If the message reappear replace the sensor.
    • Eric1968
      • 2458
      Re: MPc3500 SC 400
      Make sure to clean the sensors with a wet cloth. If you use a dry one you generate static electricity which will attract toner to the sensors.
