MP C5502 PS 3 Duplex default
  • iscott
    • Mar 2010
    • 344
    • 22927
    Re: MP C5502 PS 3 Duplex default
    Have you tried a variety of documents and applications? It appears that your looking at data captures, true?
    If it affects different applications and documents maybe you can try:
    1) PostScript Print-As-Image
    2) PCL6 emulation
    If you edit the data capture to "1 Sided" and re-send, do you get the desired affect?
    Have you confirmed that you're using a compatible driver?
