refill fuser oil in a 2238c.
  • zflash7
    • Jun 2012
    • 39
    [Misc] refill fuser oil in a 2238c.
    I have 3 of theses units (Ricoh 2238c) and use them as mass flyer printers. I dont want to blow any more fusers. But I do want to refill the oil units. I have the DIMETHYLPOLYSILOXANE all I want to do is pour it in the unit. per-say
    I have the will. does anyone know of the way?
    RE: Z.
  • rthonpm
    • Aug 2007
    • 2854
    Re: refill fuser oil in a 2238c.
    The easiest and most effective way is:
    Lanier LD232C Fuser Oil Unit, Genuine (A4215)
    or
    https://www.gmsparts.com/product_det...Fuser_Oil_Unit
    Trying to refill these is pretty much the best way to get yourself a blown fuser or a really slick floor.
    • sandmanmac
      • 3981
      Then replace the oil units as suggested. Problem (and MESS) resolved.
      • neergish
        • 177
        Are you using the high capacity Oil Unit B149 9500? Might make things easier on your fusers if your doing high volume.
        "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          RE: Z.
          A really bad idea that will go wrong............
          Mystic Crystal Revelations
          • zflash7
            • Jun 2012
            • 39
            I've been a rebel all my life so I'm going to try it anyhow.
            The hole is small and last time I spilled a bit this time I'm using a squeeze gun nozel and will pour in 50mm at a time, 400mm refill should take roughly 1/2 hour.
            ..............Rebel for life.....................though it may be short.
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • thierry
                • Apr 2012
                • 30
                RE: Z.
                Not a good idea. But if you are a rebel then do not forget to replace the fuse on the oil supply unit so that the machine can detect that "you" have replaced the unit. Secondly i would also look at the long life oil supply unit and also increase the value of your oil supply unit through SP 7905-14.
                But good luck!
                • zflash7
                  • Jun 2012
                  • 39
                  I was going to re-set the fuser oil, replace the fuse?. OK if I can find one. Thanks.
