Ricoh 2090 service in Ft Lauderdale
  • rtr0id
    Hey guys,
    I need some service on a ricoh 2090. I think there is an issue with my developer assembly. Pages are toning. I've tried several "dealers" in the area but they cant seem to fix the problem. New PM kits and developer have been installed.
    Any ideas? anyone in the area want to take a look at it?
    Thanks for the help
    pm or feel free to give me a call 954-491-4222
    Tony
  • Iowatech
    Not a service manager
    • 3930
    Re: Ricoh 2090 service in Ft Lauderdale
    If by toning you meant the parts of your prints that are supposed to be white are gray, the drum in your machine is probably worn out and needs to be replaced. The drum is not a part of any PM kit. If you get the drum replaced, it is important to make sure that the drum cleaning blade gets changed then as well.
    • Athlontini
      • Jun 2012
      • 269
      Don't forget to check if the mag roller's coated.
      • katash
        • May 2010
        • 221
        sometimes the drum does not reach the target prints seems to its a drum problem or toner issue
        • rtr0id
          600K maintence kit
          Non-Cancellable - Non-Returnable - Non-Replaceable - Should Only be Replaced by Trained Service Personnel - Kit includes: (1) Transfer Belt, (1) Feed Belt, (1) Reverse Roller, (1) Hot Roller, (1) Pressure Roller, (1) Web (Cleaning Roller), (1) Oil Supply & Cleaning Web, (1) Cleaning Blade (Transfer Belt), (1) Web Brake Pad, (5) Hot Roller Stripper Pawl, (1) OPC Drum, (1) Transport Belt, (1) Pick Up Roller, (1) Pick Up Roller Coupling - Genuine Ricoh Brand
          The last tech that was in cleaned the blade. Started clean and then 500-1000 sheets it started toning again.
          i'm thinking the developer assembly has a crack or a seal is gone because it seems i'm getting excess toner when i open the right hand door.
          thnks for the help
