Re: PMs - Kits and Assemblys
I hope this helps you out,
MPC3500/4500
You can use any of the kits that come from the 811dn series. So fuser, transfer and PCU/Dev's all work in this model with a little modification
MPC4000/5000
You can use any of the kits that come from the 820dn series. So again, fuser, transfer and PCU/Dev's all work again with a little modification
MPC4501/5501
Only kit you can use for this model is the transfer kit from the 820dn series, everything else seems to be different (please correct me if I'm wrong)
MPC4502/5502
I have successfully used the fuser kit for the 830dn series, I have not tried anything else, but I'm sure you should be able to use the transfer and PCU/Dev units, but I find the PCU's in these devices are going over double their life, so why would you bother using the maintenance kits when the PCU's keep going and going...
As for the B&W's
AF3035/3045 & MP3500/4500
You can use the Kit A and B from the 8100 series. AD3035/3045 slap straight in, MP3500/4500, fuser modification is required
MP4000/5000 and MP4001/5001
You can use the Kit A and B from the 8200 series. They are a straight swap
MP4002/5002
You can use the Kit B from the 8200 series (fuser/transfer). The PCU has a different casing which is a different size, it does not fit in these devices.
Hope this helps....
MPC3500/4500
MPC4000/5000
MPC4501/5501
MPC4502/5502
As for the B&W's
MP4002/5002
Hope this helps....
