Aficio 3035 fax function
  • mkopoiuy
    • Mar 2008
    • 54
    [Misc] Aficio 3035 fax function
    anyone can help this matter.
    model : aficio 3035
    after sending the fax my customer doesn't want a TX communication result receipt.
    how can I stop this coming out?
  • mrwho
    Major Asshole!
    • 4299
    Re: Aficio 3035 fax function
    Check the fax manual, but should be a parameter switch you need to change. Sorry, don't have the details at hand.
    Mascan42
    Ibid
    • ruben
      The New Guy
      • Oct 2012
      • 1204
      [This is all in the user guides. Please read them.]
      Go to User Tools (123 button) -> Fascimile Settings -> Parameter Setting -> Select 03 -> Select 0 (last on the right), the number above should change to 0 (from 1).
      See: http://support.ricoh.com/bb_v1oi/pub...0/B7798650.pdf (under User Parameters in Using Administrator Settings, Fascimile Featues).
      • mkopoiuy
        • Mar 2008
        • 54
        thank you very much! God bless you! it helped a lot.
