MPC 7501 SC402 and 403
  • mikadonovan
    • May 2008
    • 2931
    Hi, all. I just replaced the transfer belt and after running a few good prints I'm getting sc 403 and sc 404. I checked the connector to the id sensor, all good. I'm thinking the ID sensors are at fault. What prints that do come out are good as far as image quality. Anyone run into this before?
    NEVER ASSUME ANYTHING
  • unitechro
    supervisor
    • Feb 2012
    • 9
    [B] with a soft
    dry cloth.
    3. Keep rotating the ITB at [A] while continuing to apply the powder at [B]
    • StrippedScrew
      • Jul 2012
      • 58
      Re: MPC 7501 SC402 and 403
      Had this same prob and it drove me nuts for a week. wound up being the HV PCB inside the ITB. It was coated with toner. Vac and clean both sides of PCB and prob solved! Hope this helps
      • tjvincent
        • 280
        I had this problem also after cleaning the ID sensors, I think the machine was in shock because of a drastic change to the sensor readings, run a process self check and line adjust and I think you will be ok. This machine sucks anyway,we have stopped selling them. A new and different model is soon to be released I am hearing.
        • mikadonovan
          • May 2008
          • 2931
          Replacing the ID sensors took care of the problem.
          • Besserwisser
            • 25
            The machine that god forgott and the japs dont care about. Have had this a couple of times and this is what i do... I switch of the machine and go home. the next day i call the customer and tell him to switch on again..and so far Bingo
            4 times so far it has worked..
            • marcobill
              • Jan 2013
              • 4
              Hello
              I confirm the answer of StrippedScrew that the tranfer pcb was coated with toner
              Thank you
                • 37531
                Had the problem on a MP C6501 today after having replaced the ITB, ITB cleaning unit parts, and PTR parts. Since I knew the ID sensor was clean, I ran SP 3820-001 and SP 3820-002 IAW Goose's Guide. Problem corrected.
                • zulufan1
                  • Oct 2009
                  • 45
                  I completely agree. I work on these all day long, and I have gotten various 400 codes many times after servicing the PCU's or ITB. Now, after I do either, I run a few internal test prints of each color, and then run sp 3820-002. This seems to prevent most if not all of the dreaded after service 400 type error codes.....
                  • alexsegura27
                    • Mar 2015
                    • 10
                    Hello friends and colleagues
                    I want to ask you a question ?
                    the driver mpc6501 equals mpc7501
                    because I have a fault in a mpc7501 desire to replace it by a mpc 6501
                    Thank you!!!!!
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      Yep, exactly the same.
                      Hit it.
                        • 37531
                        Thank you!!!!!
                        If you are talking about the print driver on the computer the answer is yes. If you are talking about a part on the machine the answer depends on what part.
                        • anothertech
                          • 1771
                          Thank you!!!!!
                          Maybe start a new thread?
                          • Brianneoe
                            • May 2015
                            • 322
                            If all the workstations have the 75 drivers and you bring in a 65 unit it will print. Just make sure you set the manufactures model number to match the print driver or it may not update the machine settings correctly
