Bad separatin MPC4000
  • Bole
    • Dec 2012
    • 34
    [Jamming] Bad separatin MPC4000
    Hi,
    do you have any problem with separation in fusing unit when you copy full covered color duplex copy? The copy paste aroun hot roller. Fusing unit is on 41% of life time and it's look in good condition. It is evident that I have problem with separation but I don know what can I do? Do you know any solution?
    THNX
  • Max
    • Oct 2011
    • 561
    Re: Bad separatin MPC4000
    Full colour 100% coverage double sided will never come out. (i dont know any copier that will) Single sided will jam 9 times out of 10. Unless you have at lest 4 cm of erase on lead and trail edge it will keep jamming. What you can try is 120 gsm paper witch will resist the curl a lot more, but printing d/s on it might be difficult .
    • Bole
      • Dec 2012
      • 34
      Im afraid you are right Max. But I realy want to find solution for my costumer.
      • Max
        • Oct 2011
        • 561
        the only way would be to have a huge erase or use over sized paper then use guillotine to trim to A4 or what ever size they are using.
        • mikadonovan
          • May 2008
          • 2931
          A full bleed print is more trouble than it's worth. A substantial lead edge void area is necessary to avoid problems like yours.
          NEVER ASSUME ANYTHING
          • TonerMunkeh
            Professional Moron
            • 3865
            The solution is elegantly simple actually.... sell them a machine that can tackle full bleed, like a Pro C751, not an office colour MFP.
            Hit it.
            • Bole
              • Dec 2012
              • 34
              Yes of course, how much it cost
              • bradj
                Originally posted by Bole
                Hi,
                THNX
                Try printing/ copying on a thicker mode.. thick 3 is the best.. slows down the machine enough that fusing isn't a problem... most effective on full color duplex..
                • Bole
                  • Dec 2012
                  • 34
                  Thank you 'Bradj' you are the man! This is the answer that I expected! I'll try to do this.
                  • SargeNZ
                    • May 2012
                    • 263
                    I don't know if the 4000 will duplex thick 3. The paper/card would be too stiff to get around the U bend.
                    • kannuki2
                      • Feb 2012
                      • 398
                      Cannot duplex if its on thick 1. You can duplex with middle thick setting but not sure if full bleed will work
