MP C3000 -error
  • foundry
    • Apr 2011
    • 20
    MP C3000 -error
    This machine is driving me nuts. Gives waste toner bottle message not set correctly. Gives error sc325 as well as what appears to be an inoperable touch screen. Can get it to go into service mode but none of the touch screen works.
    I have no parts but lots of heart...at least at the moment. All devs/drums turn,cant seem to find any mechanical drag to generate the 325 error.
    Please help before I go insane
    One Look is worth a thousand guesses
  • sandmanmac
    • 3990
    Re: MP C3000 -error
    Seems to me that you've been given some decent advice regarding this EXACT problem that you've also posted in the fax forum Here: http://www.copytechnet.com/forums/ri...325-error.html
    Why not pay attention to therm, try a few of the solutions already offered by myself, and others, and then give us some feedback on your progress??
    With regards to the SC325, if the units all turn freely, then you probably need a motor.
    "Heart", unfortunately isn't going to be enough for a couple of your issues I'm afraid
    • portviking
      • Sep 2009
      • 18
      Re: MP C3000 -error
      check the touch panel to see if the connector ribbon is brown...if so you will need to replace it with the updated panel that has a white tip (B2231484) Here are the postings in Gooses guide about the SC code. Sometimes the bearings will bind up with low copy volumes. Physcially inspect the CMY developers and turn them. Hope this helps.
      SC 325 Color developer unit bound, clean or replace dev unit.
      SC 325 Color developer motor bound or defective.
      • foundry
        • Apr 2011
        • 20
        Re: MP C3000 -error
        Small foam attached to the waste toner door proved to be quite effective. One down 2 to go. Developer units appear to turn ok although I have nothing to compare as far as drag goes. Is there a means by which the machine can be tricked into thinking the devs are installed in order to try a no load test ? The display has a white ribbon cable with a green tip at CN704. There is a second (much smaller) ribbon cable located at CN706 which is brown in colour.
        White sticker on PCB under LCD is"B2381461B" It appears to me that I have the updated display although I am unable to confirm at this time. Again feedback is gratefully received.
        My apologies if I've posted in a fax forum...I saw no indication.
        • sandmanmac
          • 3990
          Re: MP C3000 -error
          The small harness is the one we're referring to, and you have the old one (brown end). It's only the actual touch screen or "contact glass" that needs to be replaced - not the circuitry. The problem is that the compound used to connect it to the screen dries out and becomes brittle, and then the panel becomes unresponsive.
          I don't know of any sort of 'load test'. I'll state again -I'm pretty sure you're looking at a developer motor
          • TonerMunkeh
            Professional Moron
            • 3865
            Re: MP C3000 -error
            Dev unit drive gears could also be at fault, they strip quite easily if the dev unit siezes.
            Hit it.
            • JustManuals
              • Jan 2006
              • 9838
              Re: MP C3000 -error
              Paul@justmanuals.com
              • foundry
                • Apr 2011
                • 20
                Re: MP C3000 -error
                Thanks for the help all. As an FYI I was looking to try to run a no load test with regards to the dev drive motor and removing the driven gears off the assemblies did just that. Error code still present. As Paul so aptly pointed out a manual would have been quite useful. I prefer not to shotgun troubleshoot particularly when no major parts are available to do so. If the part number is known for the dev drive motor I would be appreciative.
                Thanks again for all of your help
                • sandmanmac
                  • 3990
                  Re: MP C3000 -error
                  P/N
                  AX06 0311 - Brushless Motor DC24V40W (Development Motor - MCY)
