Swap finisher from Mpc4500 to mpc5000 ?
  • mrfuser
    • 1617
    Will the 2000 sheet staple finisher from an mpc4500 work on the mpc5000?
    thanks
    kelly
  • engineers
    • 51
    Re: Swap finisher from Mpc4500 to mpc5000 ?
    Both machines are compatiable with the SR3020, SR3030 and the SR790
    So assuming your 4500 has a correct finisher on it then yes
    • Imprestik
      • Aug 2012
      • 297
      This will work but you will find it will jam in the finisher entrance.
      Make you you do a firmware upgrade of the finisher once you install it on the MPC5000.
