PLEASE HELP? Aficio 2090 Toner streaking issue
  • TheKidd24
    • Nov 2009
    • 12
    I have an LD090 and copies started coming out with a black streak on the front edge. I noticed that toner is spilling between the developer and drum housing. I replaced developer and changes blade. Please help rectify this problem.
  • JustManuals
    • Jan 2006
    • 9838
    Re: PLEASE HELP? Aficio 2090 Toner streaking issue
    Paul@justmanuals.com
    • Iowatech
      Not a service manager
      • 3930
      What is the print count? You might want to swap out the developer unit if the count is pretty high (no need to have spilling developer wipe out the feed clutches, I've never had to replace them, but it doesn't sound like a whole lot of fun). Or, if there was just a big pile of only toner in the left hand side of the drum unit frame, and you vacuumed it out then changed the developer according to the procedure in the manual, you might be OK. Might not hurt to keep an eye on the condition of the seals in the drum/developer area, too.
      Anyway, that's the best I can do with the information you shared, so good luck!
      • TheKidd24
        • Nov 2009
        • 12
        Will Try this. And post results
        • tinnyjay
          • Oct 2009
          • 662
          If you upload a copy i can help you i think.
          bye
          "Who loves the roses,must also bear thumbs"
          • TheKidd24
            • Nov 2009
            • 12
            bye
            Attached is the copies coming out. The streak is toward the front of machine. on 8.5 x 11. Tries 100 copies and same results. Just stays te same or a little darkerIMG_20130124_175853.jpg
            • tinnyjay
              • Oct 2009
              • 662
              Attached is the copies coming out. The streak is toward the front of machine. on 8.5 x 11. Tries 100 copies and same results. Just stays te same or a little darker[ATTACH=CONFIG]19088[/ATTACH]
              Enter Sp Mode 2001-3 and change value to 1300 and print a copy of copycounter and see the result.
              I think its just a corona charge problem.
              Show me results plz
              Did you tried SP2801 and SP2962 after changed the developer??
              • tufbnme
                • 493
                Pull the drum unit and check it to be sure it is still clean
                • Imprestik
                  • Aug 2012
                  • 296
                  This issue has got nothing to do with drum or dev units.
                  It's your transfer unit, pull the unit apart and check the earths on the bias roller and connections to the transfer bias board in the unit its self. More than likely the board is starting to fail, so just replace the whole transfer unit.
                  • fshead
                    • 2360
                    did you swap a diff corona unit?
                    looks like typical corona wire dirty..
                    try a pencil erasure across the wire and clean the grid wth soap and water and dry well..
                    • TheKidd24
                      • Nov 2009
                      • 12
                      We just replaced the wires and grid. Looked good for a little while
                      • TheKidd24
                        • Nov 2009
                        • 12
                        Re: PLEASE HELP? Aficio 2090 Toner streaking issue update
                        I notice there is also toner on the foward part of the drum. About 1/2" worth. The toner is leaking from the front side also onto the belt and such?
                        PLEASE HELP
                        • sharpie
                          • Feb 2011
                          • 180
                          also check your air pump is working. the hose can plug between the developer housing and the pump to the waste toner bottle. no air displacement will cause toner to be forced out at the add point which is at the front of the DV unit.
                          • TheKidd24
                            • Nov 2009
                            • 12
                            Attached are pictures I took. Of where the toner is collecting it looks as I do prints to be coming out of the small hole right to the springUntitled-4.jpgUntitled-5.jpg
                            • tinnyjay
                              • Oct 2009
                              • 662
                              Attached are pictures I took. Of where the toner is collecting it looks as I do prints to be coming out of the small hole right to the spring[ATTACH=CONFIG]19154[/ATTACH][ATTACH=CONFIG]19155[/ATTACH]
                              There is nothing to do with developer.
                              You have problem with cleaning.
                              First check quenchin lamps(disscharge lamps) if they are dirty in that area of drum and if they are dirty,just clean them,otherwise change drum cleaning blade.
                              If this cant help,you have a bad drum.
                              Do what i said and do not ask anymore questions.
                              Bye
