problem with ricoh mpc 4500
  • muthana
    • Nov 2012
    • 23
    hi all
    i have mpc 4500 after i do copy with color the copy exit with ligth background if thier is any program i chang it with sp program to clear or remove this background
    best regards
  • lganaden
    • Jan 2013
    • 10
    Re: problem with ricoh mpc 4500
    just enable the auto density...............good luck.....
    • rsyarcia
      Hair Straightener Tech
      • 711
      maybe you have to do PM
      Nobody is perfect..
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
        Paul@justmanuals.com
        • kannuki2
          • Feb 2012
          • 398
          yes indeed.... PM stands for Preventive Maintenance just in case you've never done one...
          • turbojetboy
            • Aug 2009
            • 279
            Sounds like its had a "memory clear" to me, that always fixes em.
            • Iowatech
              Not a service manager
              • 3930
              I'm guessing one or more of the drum units need to be replaced. Here's the deal, when the drum coating gets worn down enough, the drum will attract toner to places that should be toner free.
              I suppose it could be a drum ground problem also, I haven't seen that for a while but if you have time you might want to get your meter out and check that, too.
              Still, sounds like checking the PM table to fix this is likely going to be your best bet.
              As far as adjustments go, I've had rather poor luck trying to adjust my way out of something like this. If anybody else knows better than me, hopefully they can help you out with that.
              • sandmanmac
                • 3983
                That's EXACTLY what it sounds like to me too, and if there isn't a copy of the 'non-defaults' inside the front cover, that' s a big DOH!
