2045 with sc 990
  • Teng Wai Hoo
    • Jun 2025
    2045 with sc 990
    good day everyone ....
    first the machine came out SC 990 , normally i changed the new drum ,. the problem can be solved , but this time i changed the new drum , the problem came back after few hundred copies . I thought maybe the new drum problem so i decided to changed second new drum but the SC code came back after few hundred copies too . Please help
    should i 'memory clear '???
  • sandmanmac
    • 3979
    Re: 2045 with sc 990
    You may try another Drum unit. Could also be HDD, LD unit, NVram, etc.
    Allow me to do a search for many of the possible causes and solutions for you. There are dozens of threads:
    • portviking
      • Sep 2009
      • 18
      the SC990 has alwas been related to firmware NOT the drum. Here are some suggestions
      [SC990] - A852, Upgrade Firmware; Copier-latest Finisher-D
      [SC990] - re load copier firmware
      [SC990] - replace BICU
      • sandmanmac
        • 3979
        I beg to differ...here's a few more causes and the reason for my initial reply:
        SC 990 [SC990] - replace drum - poor or damaged drum effecting patches -
        SC 990 [SC990] - replace HDD
        SC 990 [SC990] - replace nvram
        SC 990 [SC990] - replaced drum drum damaged and arcing
        SC 990 [SC990] - wrong fax option installed, B135/B138 uses B653 edp 411848 MCU B134 and B079/B082 uses B547 edp 411347 MCU B078
        SC 990 [SC990] - wrong fax option installed, B135/B138 uses B653 edp 411848 MCU B134 and B079/B082/B135/B138/B182/B183 uses B547 edp 411347 MCU B078
        SC 990 [SC990] - wrong printer/scanner dimm installed B654 needed for B135/B138 series.
        SC 990 clear nvram - all
        SC 990 gray patch density incorrect, runs OK when in Pixel mode
        SC 990 Install correct Printer DIMM for model machine
        SC 990 PM machine
        SC 990 Reflash firmware
        SC 990 repair pinch wire in interchange unit
        SC 990 replace developer
        SC 990 replace drum
        SC 990 replace drum & poor or damaged drum effecting patches
        • cleardata
          • Jul 2011
          • 137
          try replacing the id sensor.
          • kannuki2
            • Feb 2012
            • 398
            replace all front safety switches. especially the three on top of the fuser.
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • Zeldaman
                • Mar 2011
                • 946
                Hi there!
                In the last 2 weeks 3 machines with this issue, the problem allways disapeared after changing the ID-sensor. I think the sensors getting "old" & sending crap-datas.
                Greetings...
                • andrewdecruz
                  • Jul 2009
                  • 74
                  I hv faced countless problems relating to sc990 and always got it solved...but its far too deep and complicated to elaborate on it here..
                  Just emailed me at : andrewdelacruz007@yahoo.com to get the full details..cheers
