MPC 2500 Pink copy/scan
  • whitecat
    • Nov 2012
    • 43
    Hi , im haveing a weird problem with an mpc2500 , If i try to copy or scan color mode , i get a pink backround( ADF or Glass ). If i print something in color , everything is OK. I cleaned everything i could. in the scanner area, acc didnt helped.Is there a way to calibrate/initialize the scanner?
    Ps:Pink is not my customer fav color. XD
  • engineers
    • 51
    Re: MPC 2500 Pink copy/scan
    Sounds like you may have had a memory wipe, hope you still have the original non-default data SMC handy.
    'Gray Balance Set' is what causes this, set it back to factory defaults.
    Alternatively if you find no cure, default 'auto density' to on for colour, i believe this sorts it (well it by-passes the problem)
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      Paul@justmanuals.com
      • TonerMunkeh
        Professional Moron
        • 3865
        x2. Have you done a memory clear for any reason? Check under the jam removal decal in the front cover for the birth certificate.
        Hit it.
        • okirob
          • Feb 2012
          • 26
          use the birthmark provided with the machine cant remember the exact sp but it will say adf and then book and there are 3 different areas set them to current and that should correct your issue
          • Debs1964
            • Oct 2010
            • 1687
            Try doing a memory clear on COPIER APPLICATION only, I've had machines where there was bad CQ issues on copying, but printing was perfect, this cured it for me. SP5801 then scroll down to copier application
            There are 10 types of people in this world, those who understand binary maths and those who don't
            • kannuki2
              • Feb 2012
              • 398
              Do you get the background when you do a single color copy off the platen glass?
              If not then probably A.D.S is enable causing a background effect like a halo.
              • CableGuy
                Impulse Drive Engineer
                • Oct 2008
                • 417
                Has someone had a fiddle the the colour balance in the user settings? I've had blue back ground because of this previously.....
                • whitecat
                  • Nov 2012
                  • 43
                  U r right , the problem is that im not the only1 with admin acces , also the IT department has acces , they usually create accounts and stuff like this , but some1 made a clear all memory ......
                  Now the machine works great , lucky me that i found the factory settings paper
                  TY
                  ( sry for the late rply , vacation)
                  • Iowatech
                    Not a service manager
                    • 3930
                    Um, you probably would be best served if you follow a the previous posts here. But I didn't see where you tried to change the magenta drum, and maybe the magenta developer as well. At least that's what I would have tried first.
                    • collme
                      Ricoh tech
                      • 221
                      He did say colour prints were coming out fine which rules out the drums and devs. had to be settings or scanner unit as it occured in scans as well.
                      • jonhiker
                        • 661
                        kannuki2 is correct and this setting can be changed in user tools:copier/docserver functions.
                        • sasa12u
                          • Nov 2011
                          • 39
                          Try goto copysp mode,
                          4685-1=set to -60
                          4685-2=set to -60
                          4686-1=set to -25
                          4686-2=set to -25
                          4687-1=set to -50
                          4687-2=set to -50
                          • redneckstylin
                            • Sep 2011
                            • 173
                            its the df read crap sp4xxx thats what happens when you swap nvram out
                            • Iowatech
                              • 3930
                              OOPS! Sorry for the wrong info.
                              With that in mind, it kind of sounds like the SBU on that machine has gone bad. Still, the other posts here are better than mine, so you should try them first, and you might even try playing around with the gamma settings in scanner service mode too before you replace the SBU, I occasionally have had some luck with that for color scanning issues back in the day. (If you do replace the SBU, make sure all of the the gamma settings are all set back to default values (I think that is 15), though.)
