MPC 2500 Pink copy/scan
  • okirob
    • Feb 2012
    • 26
    #16
    Re: MPC 2500 Pink copy/scan
    Originally posted by sasa12u
    Try goto copysp mode,
    4685-1=set to -60
    4685-2=set to -60
    4686-1=set to -25
    4686-2=set to -25
    4687-1=set to -50
    4687-2=set to -50
    the exact settings on the particular machine can be found on the bithmark, this should fix the issue we have had this issue b4
    • jaykub
      • Sep 2020
      • 3
      #17
      This is automatically caused by a bank security feature in some checks.
      Shrink to 65% to allow copy and scan to folder Scan to email.
      Originally posted by whitecat
      Hi , im haveing a weird problem with an mpc2500 , If i try to copy or scan color mode , i get a pink backround( ADF or Glass ). If i print something in color , everything is OK. I cleaned everything i could. in the scanner area, acc didnt helped.Is there a way to calibrate/initialize the scanner?
      Ps:Pink is not my customer fav color. XD
      • jaykub
        • Sep 2020
        • 3
        #18
        Originally posted by collme
        He did say colour prints were coming out fine which rules out the drums and devs. had to be settings or scanner unit as it occured in scans as well.
        • jaykub
          • Sep 2020
          • 3
          #19
          Shrink to 65% to bypass bank check security automatic black Re: MPC Pink copy/scan
            good job you have unearthed a thread that has been dead since 2013 .. 2 years is the acceptable time frame to reply to a thread ..
            we ALL know about the security feature we have covered in a plethora of threads.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              #21
              Nice work Jubjub
              A 7yr old post.
