Ricoh Aficio MP4000
  • mansart
    • 852
    Ricoh Aficio MP4000
    Need to check what the default fax receive speed is set at.
    Long story, it is one of those its their fault no it their fault situations and as usual I'm right in the middle.....
    TIA
  • Eric1968
    • 2458
    Re: Ricoh Aficio MP4000
    33.6 kBps.
    • ucinn
      • Jun 2009
      • 383
      TIA
      Drop it to 14.4, turn off ECM and boost the equalizers up..cures most ailments.
      • mansart
        • 852
        Thanks.....how do I do this? Is it in User Tools? Web Interface? Softswitch?
        • ucinn
          • Jun 2009
          • 383
          if you have the manual, it's under fax sp modes in fax service mose under bit switches. I believe one is a communication swith and the others are in the G3 switches. If you don't have the manual, then I'll have to look them up again and get them to you tomorrow.
          • rthonpm
            • Aug 2007
            • 2854
            Disable ECM with Fax SP 1-104-002 Change bit 0 to 0. You may also want to print out the error report in the Fax SPs to get a better idea of what the machine is having issues with.
