mp 5001
  • T911
    • Jun 2007
    • 628
    mp 5001
    This one is in a surrogates office. All copy jobs are good with white originals, any size. But when I try to get a copy of a death certificate (blue original) I get half of the image that is fine and the rest of the copy is totally black. Only with this color original. They yellow. Green. And peach which work fine. The blue I'm having trouble with is not a light or dark blue its somewhere in the middle.
  • tcs04
    FORMER Techie
    • 1183
    Re: mp 5001
    Silly (?) question? Auto or manual I.D?
    I'm taking a leap of faith here and assuming the Auto I.D system harks back to the older (MUCH older!) versions... AF2035 etc Which would give odd results with colours and solids on certain parts of the original in auto I.D mode..... see attached
    • T911
      • Jun 2007
      • 628
      Re: mp 5001
      Went back with sbu and ibu boards. Still half black copies from middle to trail with this blue original. Is there a scanner setting I need to tweak for color originals. Thx for any help
      • rthonpm
        • Aug 2007
        • 2859
        Re: mp 5001
        Is it possible that the background design is triggering the anti-counterfeit function? Try enlarging or reducing the copy by 10-15 % and see if you get the same result.
        I had a law firm that tried to copy currency as part of a receipt and they got something similar...
        • copymutt
          • Aug 2008
          • 107
          Re: mp 5001
          Sure sounds like the counterfit protection, Try moving the original down the page if its less than letter size or reducing it.
          If it copies well the above is confirmed.
          Copymutt
          • T911
            • Jun 2007
            • 628
            Re: mp 5001
            Copymutt
            I tried different locations on the glass and reducing from legal to letter. Still the same thing. I think ur on to something with the counterfit. It is a death certificate that is giving me trouble in a surrogates office.
            • copymutt
              • Aug 2008
              • 107
              Re: mp 5001
              Just a thought on defeating/confirming counterfir protection. Maybe try text/photo or generation settings to hopefully overide the C/F kiking in.
              • T911
                • Jun 2007
                • 628
                Re: mp 5001
                Yep, got u, tried that no luck.
                • totoro
                  • 568
                  Re: mp 5001
                  Just a thought , because I've never tried it myself, but what happens if you try scanning it to the doc server or to a folder or e-mail? Does it show up half black
                  Totoro
                  • T911
                    • Jun 2007
                    • 628
                    Re: mp 5001
                    On the network but not using scan just print. Not set up to any terminal. Good thought.
                    • copymutt
                      • Aug 2008
                      • 107
                      Re: mp 5001
                      Might be time for old school t.s. Can you make a copy on another machine that has no copy write protection & then try that copy on the 5001. If the result is the same I would assume you've ID'd the cause as copy write protection.
                      Copymutt
                      • T911
                        • Jun 2007
                        • 628
                        Re: mp 5001
                        Copymutt
                        Yep did that, they have another 1060 that it works fine on. But what could the solution be on this 5001.
                        • Shadow1
                          • Sep 2008
                          • 1642
                          Re: mp 5001
                          In order for this not to trip the counterfeit protection the copy must be enlarged more than 150% or reduced more than 50% - I fought with this at a county tax office where the state seal on their letterhead tripped it. Strange thing was that it would also activate in print mode, not just copy. Just cut a post-it to fit over any seal, and try it again. If indeed this is what's causing your problem, then I'm sorry, but there is no fix for it. Ricoh made the copy protection a lot stricter after people discovered they could copy money by placing it at a 45 degree angle on some old color machines, or simply use a B/W machine and custom mix their own green toner and developer.
                          Be thankful this isn't one of the really old color copiers where the anti-counterfeit software would completely brick the machine and an FBI agent would have to be dispatched to investigate and unlock it.
                          73 DE W5SSJ
