mpc 7501 sc 409 and 413
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    [Error Code] mpc 7501 sc 409 and 413
    I am visiting this machine tomorrow that is regularly rebooting due to the above codes. I have cleaned the id sensors and I got the codes again. I am going armed with drum. Blades. dev. Also going to give the potential sendor for yellow a clean. Anything in particular I should look out for as I want to get this sorted this time...
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • turbojetboy
    • Aug 2009
    • 279
    Re: mpc 7501 sc 409 and 413
    As per your footer "Networking skills are advantageous but use of a 3m vacuum cleaner is essential" well you are about to give that vac the work out of it's life!
    FYI and not trying to be silly here...Unless you are very experienced with these machines and the previous models (7500 and 3260) I would advise you to arrange a tech that is. They are a unique case that requires a good understanding of their inherant issues. Good Luck - let us know how it went. I would have expected to see the other PCU's requiring work also.
    • leo34staffs
      copierman
      • Aug 2007
      • 503
      Thanks for the repliy. The machine has recently been refurbished ( so im told) but I will look at the other pcus. Coincidentally another tech is looking at this machine with me who has more experience. I have seen many posts of their troubles and relevent tech bulletins regarding dev setup and other issues. The problem with said machine is that its a trade machine that I have no history of! I will let you know how I got on in any case.
      • TonerMunkeh
        Professional Moron
        • 3865
        I've got two V-3's doing this on our patch. I've escalated it to Product Support and I'll let you know what I hear back. They seem to respond to a damn good vac out, literally every part of it, but I don't know about a final fix yet.
        Hit it.
        • leo34staffs
          copierman
          • Aug 2007
          • 503
          I rebuilt Y PCU and also replaced c,y and m devs as i was not happy with the cq.
          The one issue we did have though, was that the auto dev fill would not start so we had to manually fill the dev ubit before initallizing it.
          The toner does not vac off that easy neither, despite me having a powerful 3M Vacuum.
          All results and checks were displaying good readings 10101010 for process control and dev setup showed 1111.
          Fingers crossed.
          • TonerMunkeh
            Professional Moron
            • 3865
            Right, product support's resolution on this was to replace the entire transfer belt assembly and the yellow PCU including developer unit. The SC's stopped after that.
            Hit it.
            • leo34staffs
              copierman
              • Aug 2007
              • 503
              Thanks for the reply, i suppose rebuilding the y unit (drum and dev) sorted it for me, although their blanket approach to the fix is going to give more piece of mind.
              • TonerMunkeh
                Professional Moron
                • 3865
                It may not do, I did this before I had to call PS in. Sorry to be the bearer of bad news.
                Hit it.
