Mp4000 fuser web hub Allen screw size?
  • mrfuser
    • 1616
    Anyone know what size the Allen screw is on the hub gear for the mp4000 fuser web? I can't seem to find the right size !
    thanks all
    kelly
  • Eric1968
    • 2458
    Re: Mp4000 fuser web hub Allen screw size?
    0573 0030E Hexagonal Set Screw - M3x3
    • teebee1234
      • Jul 2008
      • 1670
      1.5 mm
      • billm
        • Jun 2012
        • 50
        try this sight for a striped web gear
        • wester
          • Aug 2009
          • 113
          I have been doing this nfor a couple years now, works good. Sometimes you will have to cut of the shaft at the gear, but you cut it off to disassembe.need the shaft any long so no problem, you just need to
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            It's a metric set that you need...Imperial just doesn't cut it.
