Ricoh 2550 Not Fusing
  • callmefirst
    • Feb 2012
    • 51
    [Misc] Ricoh 2550 Not Fusing
    I have a 2550 that does not fuse the first two copies, first thing in the morning. The machine does fine the rest of the day. ??? Any ideas would be helpful
  • zames77
    Tweak it till it breaks!
    • 121
    Re: Ricoh 2550 Not Fusing
    Depends, could be that it's not coming up to temp quick enough when waking from energy save, so you might need to bump the temp up. Might be that the room the machine is in is quite cold first thing, or the paper is slightly damp. I'd start by flipping the paper stack before any print/copy jobs are pushed through and go from there.
    • nmfaxman
      • 1702
      Turn on fuser idling.
      It will make the fuser turn and distribute the heat evenly before printing.
      • sandmanmac
        • 3980
        100%.
        It's interesting, I don't think I've had more than 1 or 2 cases where I had to enable idling the last decade or more - and it was usually in a location like a construction trailer or somewhere similar that tended to be very cool in the morning. This year, I've had at least 6 machines that I've had to turn it on - a couple of the MP2550 series, and also a few of the MP2000/2500 series. I'm wondering what might have changed? Maybe a slightly different metal thickness in the hot roller or something?? Just wondering if anyone else has experienced an increase in this type of call
        • rthonpm
          • Aug 2007
          • 2849
          There was also a firmware update for this type of issue: make sure the engine version is at least 1.05.06
          • TonerMunkeh
            Professional Moron
            • 3865
            MP or MPC?
            Hit it.
