MPC 3001 with SC 672
  • Codex
    • May 2008
    • 701
    [Dead] MPC 3001 with SC 672
    Hello
    I have big problems with an Aficio MPC 3001, it shows a SC 672, i've replaced the BICU, NVRAM ,HDD, MEMORY MODULES and the CONTROLLER BOARD............code still remains!!, any ideas???????
    Memento Audere Semper
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MPC 3001 with SC 672
    Did you reseat all connections between the control panel and it's controller board? (That is what this SC number is about).
    • incognegro
      • Feb 2013
      • 20
      Originally posted by Codex
      Hello
      You have to replace the motherboard. It's the board that the controller and MFP options plug into. Good luck!
      • zames77
        Tweak it till it breaks!
        • 121
        I'd try another ops panel first, and if that does't sort it, check your harness between the ops panel and the controller for a pinched wire. Only yesterday I had this issue, but in my case it was the controller.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • Codex
            • May 2008
            • 701
            Yes i replaced the controll panel....but still SC672.........
            • Codex
              • May 2008
              • 701
              UPDATE!!!
              Problem solved!.
              changed the fuser inductor!! (IH-SUB ASSY)......now everything ok!
