RICOH MP6001
  • manoj.k.nair
    • Sep 2012
    • 50
    RICOH MP6001
    desar all.
    i have a problem with ricoh mp6001. copier gets hang after its get ready.i check the controle board and up date the firmware. i suspect there is problem with A C drive board.
    any body found this problem /please help me.
    regards.
    manoj.k.nair
    M N AIR
  • Eric1968
    • 2458
    Re: RICOH MP6001
    What do you mean by "hang"? Are there any SC's logged,can you go into service mode or user menu? More info please.
    • anothertech
      • 1771
      Re: RICOH MP6001
      Try formatting and/or replacing the hard drive.
      • manoj.k.nair
        • Sep 2012
        • 50
        Re: RICOH MP6001
        Thanks for u r mail. After copier shows ready none of the panel keys are working.
        IF OPENING THE FRONT DOOR , THE COPIER SHOWS READY.
        I REMOVE THE CONTROLE BOARD AND CHECK WITH OTHER MP 6001 IT IS WORKING FINE. I UP LODED THE NEW FIRMWARE.
        THE FUNNYEST THINGS SOME TIME NONE OF THE PANEL LIGHT IS NOT WORKING. SOME TIME THIS COPIER WILL WORK .
        I HAVE ABLE TO PRINT THE SMC AFTER UP LODE THE FIRMWARE.
        I SUSPECT THE PROBLEM WITH THE POWER SUPLY OF THE AC FILTER BOARD.
        IF U KNOW ANY IDEA PLS MAIL ME,.
        THANKS.
        MANOJ.
        M N AIR
        • manoj.k.nair
          • Sep 2012
          • 50
          Re: RICOH MP6001
          Originally posted by anothertech
          try formatting and/or replacing the hard drive.
          i done the formating and the controle board and hdd is working in other copier.
          M N AIR
          • rsyarcia
            Hair Straightener Tech
            • 711
            Re: RICOH MP6001
            As Eric mentioned see the SC Codes on SMC, It will help you isolate the problem.
            Nobody is perfect..
            • Eric1968
              • 2458
              Re: RICOH MP6001
              THANKS.
              MANOJ.
              Looks like a control panel problem, or the control panel gets no power.
