Nashuatec MP2000 - Skew image
  • brunot
    • May 2012
    • 148
    [Misc] Nashuatec MP2000 - Skew image
    Dear All
    When i use the scanner or ADF unit to make a copy,i have a skew image.
    The counter print is ok and the image is well aligned on the drum.
    I have also replaced the clutch,the front and rear bushings of the registration roller.
    Please adviced.
    Bruno
  • rthonpm
    • Aug 2007
    • 2859
    Re: Nashuatec MP2000 - Skew image
    Lift up on the frame of the scanner unit from the front left side. It sounds like someone's been leaning on the op panel and shifted it.
    • brunot
      • May 2012
      • 148
      Well noted
      Bruno
      • Eric1968
        • 2458
        You can also remove the right screw of the right adf hinge, and put it in the larger hole right next to the original hole. Then you can adjust the adf position.
        • Polarbear
          • Feb 2012
          • 1070
          A quick check to see df to scanner alignment, is to look down the right side of the scanner housing. The df should line up with the scanner frame - if it is skew, you will see it straight away. The hinges on these dfs are not the strongest, and can bend should someone move the machine by shoving the df.
          Press the GREEN button!!
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
