MPC2050 Firmware upgrade failing
  • sjp82
    • Aug 2025
    Hi
    Im quite new to this and would appreciate some advice. I'm trying to upgrade our machines firmware. I go into WIM goto firmware update and select the file click update and appears to work. The machine says its accepted it and restarts. After this the original version shows and if I go back in it say the the firmware is incorrect?
    Could someone help me on this please.
    Is there another way to upgrade directly.
    Simon
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MPC2050 Firmware upgrade failing
    Is there a reason for the firmware update? If it isn't broken, then no need to fix it.
    Best to use an SD card to update the firmware, if you have it connected to the network the update can get interrupted by an end-user or network fault.
    To use an SD card, find one that is at least 128MB. Create a folder in the root directory called romdata, then within create a folder with the name of the firmware (.fwu) files. E.g. If you have a file X1234567Y.fwu, create an X1234567Y folder and place the files within.
    Turn off the machine and unplug. On the rear-left of the machine, there is metal plate held on with a single screw. It should have a [1] and [2] next to it. Remove the plate and place the SD card in the [2] (bottom) slot. Turn on the machine and follow the update instructions, you will need to use the number pad to select the modules to update. Current versions are shown to the left of the card versions. Don't turn off the machine or remove the card until it tells you to.
    If you have the remote firmware files (.rfu) then you will need to re-download the non-remote versions.
    • sjp82
      Hi
      Thanks for the help. I was trying to upgrade via WIM with fwu files. Is there a way to get hold of the remote files?
      Regards
      Si
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Best to do it directly, not all firmware is available as remote. You can still download them through Tessa, if you have a login, or through My-Ricoh; again, if you have a login.
        • sjp82
          Hi
          I dont have a login for either. Do you happen to know which is the latest firmware to look for?
          Si
          • JustManuals
            • Jan 2006
            • 9838
            I can get this firmware, but it isn't free. If interested, email me at Paul@justmanuals.com
            • mikadonovan
              • May 2008
              • 2931
              Ruben just explained the procedure for updating your firmware. Don't you have a SD card? Format your card using the Panasonic SD card formatter (free download), then use this file structure. romdata> D038> your FWU files. Follow his instructions to load the files onto the machine. Forget about the RFU files, your making this way too complicated. If this is all Greek to you, you need to call your local Ricoh service rep. If you load the wrong files onto your machine, you will fubar it.
              NEVER ASSUME ANYTHING
              • knightfall
                • Jul 2006
                • 633
                Originally posted by sjp82
                Hi
                Si
                then you have to call a certified service tech to do it.
                but are you updating just for the sake of updating or was there a problem originally that brought you to the conclusion to update the firmware?
                some of the ricoh copier after an firmware updates causes the hard drives to fail I only update if there is a problem that can be solved by firmware.
                good luck
                Get your facts first, and then you can distort them as much as you please.
                • sjp82
                  Thanks to everyone for their help. I managed to get it done with the SD card in the end.
                  Does anyone know the latest firmware version number for this machine ?
                  Regards
                  Si
