REX ROTARY PRO1357 EXP
  • atech
    • Aug 2010
    • 89
    [Misc] REX ROTARY PRO1357 EXP
    REQUIRED MAINTENANCE: FUSER-CLEANER. The machine was already replaced with web roller, but the message still appears on the display. Is there a way to reset this message? Please help....
  • tcs04
    FORMER Techie
    • 1183
    Re: REX ROTARY PRO1357 EXP
    Check the TCRU replacement guide.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • FMC
        • Aug 2008
        • 88
        Had this and nothing worked at all. In the end I did an engine clear and it worked. Just make sure you print out an SMC data sheet just incase you need to refer to it for lost settings.
        • Ollie1981
          Toner Monkey
          • Mar 2008
          • 418
          Set 1-902 Web Counter back to "0"
          Or I believe you can reset the web count in the SP screen for "Trained Users",
          The message will still be displayed even if you have physically replaced the oil web as there is no mechanism for detecting how much is remaining, just a percentage indication in SP 1-902 based on page count since it was last zeroed.
          • atech
            • Aug 2010
            • 89
            Sir I cant access to simulation. I think its looking for a key operator code. and asking me to log in... Do you know how to access to simulation? Could you give me the exact execution procedure to enter into Simulation.
            • JustManuals
              • Jan 2006
              • 9838
              Sounds like you need the manual
