Ricoh MP161
  • GeorgeBest
    • Jul 2009
    • 526
    Ricoh MP161
    Tried to install this machine using scan to folder. But when I'm logged in throught webinterface there
    is no scanner utility in the configuration. Strange, I can make an adres in the adresbook for scanning, but
    only scan to email, there is no field for entering the pad where to scan to . . ?
    someone a clue here, do I need to make a full memory clear here ? It is a MP161SPF
    thanks in advance . .
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP161
    Does the scanner option appear in user tools and when you actually press the scanner function button?
    Hit it.
    • GeorgeBest
      • Jul 2009
      • 526
      Re: Ricoh MP161
      Yes, that works, you can adjust the scanner in the user tools
      • ruben
        The New Guy
        • Oct 2012
        • 1204
        Re: Ricoh MP161
        Post a screenshot of what the address book entry screen looks like.
        • Eric1968
          • 2458
          Re: Ricoh MP161
          When you add a new user in the adress book, at the bottom of the screen you must see SMB scanning where you can put the path to the (shared) folder ( \\hostname_or_ip-adres\shared _folder ).
          • GeorgeBest
            • Jul 2009
            • 526
            Re: Ricoh MP161
            Yeah, I know that Eric, I configured a lot off MP161 using scan to folder.
            The problem is that there is no field were I can enter the pad . . ?
            Only a field for entering the email adres (in adresbook)
            As I said, in the configuration of the machine, in the webinterface, there is no "scanner" item
            Again, I know how to configure the scan function, but never had this problem
            • Eric1968
              • 2458
              Re: Ricoh MP161
              Can you add a path on the machine in Key Operator Tools? Maybe updating/reloading the websystem firmware.
              • GeorgeBest
                • Jul 2009
                • 526
                Re: Ricoh MP161
                will see tomorrow, do the firmware update and memory clear
                we'll see
                thnx
                • Eric1968
                  • 2458
                  Re: Ricoh MP161
                  Please dont do a full memory clear! A full memory clear should only be done when replacing an NVRAM.
                  Use SP5-801-011 NCS Clear. This will reset network settings, WebImageMonitor settings.
                  • GeorgeBest
                    • Jul 2009
                    • 526
                    Re: Ricoh MP161
                    memory clear did not do it, swapped the machine for another . . .
                    screenshot;
                    • sandmanmac
                      • 3990
                      Re: Ricoh MP161
                      This seems like an SD card issue to me...wrong slot, "locked", or just plain FUBAR maybe? I've seen a similar thing on an MP2020 when card was in the wrong slot (self-inflicted mistake). Otherwise, I have no idea
                      • GeorgeBest
                        • Jul 2009
                        • 526
                        Re: Ricoh MP161
                        • TonerMunkeh
                          Professional Moron
                          • 3865
                          Re: Ricoh MP161
                          Oooh hang on, is this one of the GDI or GW MP161's? The GDI's won't allow any scanning other than TWAIN I think. Explains why the address book entries aren't appearing. Do you print to it using the DDST driver?
                          Hit it.
                          • Jomama46
                            • 2900
                            Re: Ricoh MP161
                            Or maybe its really a 161f, not spf
                            sigpic
                            A+; Network +; PDI+
                            • GeorgeBest
                              • Jul 2009
                              • 526
                              Re: Ricoh MP161
                              It is an MP161SPF
