Ricoh MP161
  • PinevskiS
    • Jul 2009
    • 283
    #16
    Re: Ricoh MP161
    Originally posted by GeorgeBest
    Tried to install this machine using scan to folder. But when I'm logged in throught webinterface there
    is no scanner utility in the configuration. Strange, I can make an adres in the adresbook for scanning, but
    only scan to email, there is no field for entering the pad where to scan to . . ?
    someone a clue here, do I need to make a full memory clear here ? It is a MP161SPF
    thanks in advance . .
    I had this problem once.
    SD card was inserted in the wrong slot, move it.
    If this does not help, Login in as an administrator USER supervisor without PASSWORD,
    maybe you have a ban on fully using the ADDRESS BOOK.
    B.R.Saso
    • anothertech
      • 1771
      #17
      Re: Ricoh MP161
      Any resolve on this? I'm having the same problem with no scanner section showing up in WIM.
      I'd like to use WIM to set the scan to email default to pdf, or is there another way to do that on this machine?
      There is no "program" button on the control panel to set the defaults on this machine.
      • Herostrat
        • Oct 2012
        • 220
        #18
        Re: Ricoh MP161
        Try uploading NVRAM from machine with fully working scan to folder.
        Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
        • anothertech
          • 1771
          #19
          Re: Ricoh MP161
          I don't have another machine to work from. I'm going to ver up the Frimware and check to make sure the sd card is in the correct slot, hoping for the best.
          • Moza
            • 232
            #20
            Re: Ricoh MP161
            Does this machine have a hard drive installed ?
            • anothertech
              • 1771
              #21
              Re: Ricoh MP161
              I guess I dont know if it has a harddrive.. All I'm trying to do is set the default file type to pdf when scanning.
              Scanning is already setup and working, they have to change the file type from tiff to pdf every time they scan.
              • mikedci
                • Jul 2010
                • 227
                #22
                Re: Ricoh MP161
                setting default file type for scanning is done through user tools on this machine.
                user tools > scanner features > send settings > file type priority
                • GeorgeBest
                  • Jul 2009
                  • 526
                  #23
                  Re: Ricoh MP161
                  No HDD
                  • Moza
                    • 232
                    #24
                    Im pretty sure you dont get full address book function unless you have a hard drive installed.
                    Also there are no settings for scanner through the web interface with this controller
                    • sandmanmac
                      • 3981
                      #25
                      Re: Ricoh MP161
                      No HDD for this box, and yes, all settings can be viewed, and changed via the WIM assuming that it is in proper working order.
                      HDD is Optional for the MP171 onward, but not required for basic scanning functionality.
                      But it would be nice to know if George ever found a solution?
                      • GeorgeBest
                        • Jul 2009
                        • 526
                        #26
                        Re: Ricoh MP161
                        From what I remember, the controll board was swapped.
                        I was quite busy at that time, I did not repaired it myself.
                        Greetz
