Hello everyone,
I'm having this MP C2800 with color registration problems. The CMY-colors are moved half a mm to the right (Sub Scan-direction). When I do Line Positioning Adjustment (SP2-111-003 and SP2-111-001) the machine says 'Completed' in both SP's, which is very strange because the machine should give 'Failed' when the colors are this far off. After Line Positioning Adjustment, when I print a test page (Printer SP1-103-002) I see no improvement. Density is ok, but I get the same color shift. The machine gives no SC's and all adjustment results are ok.
I can adjust the CMY-colors with SP2-101-001/008 (Color Registration Correction). Then the test page is ok, but when the machine starts to do a Line Positioning Adjustment the color shift is back.
I allready replaced the Transfer Belt Assy, ID-sensor Assy and Laser Unit, but no result. Black PCU has done 70k, Color PCU's 26k.
I'm thinking of a Black PCU-Motor and/or a BICU-Board, but maybe someone has this problem before and has found a solution.
