MP2500SP lost the SP part of it
  • mrwho
    Major Asshole!
    • 4299
    [Electrical] MP2500SP lost the SP part of it
    I'm servicing an MP2500SP (not the color model, mind you) which apparently lost all of the extras aside from the base copier-only model. Even when entering service mode, I've only got the option of getting into Copy SP - all the other modes are absent. Flashing the firmware (which only gives me the copier options) and enabling the network and usb connectors SPs gave no result whatsoever.
    I never installed one of these anew, but since it has MP2500SP on the door badge, I believe it came with scan/print from factory.
    Any ideas?
    Thanks in advance!
    Mascan42
    Ibid
  • sandmanmac
    • 3963
    Re: MP2500SP lost the SP part of it
    It likely could have had all the options pre-installed, but have you made sure they are still intact? Starting with the Print/scan SD card in the bottom slot? Do we know if the functions were working up until recently or not?
    • mrwho
      Major Asshole!
      • 4299
      The machine has no SD card installed, although, when checking the installation procedure on the manual, I don't see any mention of it anywhere. Should a printing/scanning MP2500 have an SD Card for sure? If so, then someone must've used it to store porn or something...
      Mascan42
      Ibid
      • sandmanmac
        • 3963
        Very funny!
        Yes, it needs (at minimum) a card in slot one
        MP2500.pdf
        • Polarbear
          • Feb 2012
          • 1070
          I have just confirmed this with one of my field techs that work mainly on these models. SD card =yes.
          Press the GREEN button!!
