I have worked on Ricoh/Gestetner/Savin machine before but never had to set one up as a scanner. Had a customer that purchased this on-line and wants it to scan. It copies, faxes, prints OK. But I can not figure out how to setup the scan feature on this machine. When I select SMB to search the network it never finds anything. They have a Win 7, 64 bit machine they are using as a server. But the copier does not see anything on the network, I just get a message that it can ot connect to the PC ( or something like that). You can go to any PC and put in the IP address of the copier and view the setting in tjhe machine. I need help on this one.
I can set up Canon's all day long but this Ricoh is kicking my bu**. Does it need a upgrade or something or wrong am I doing wrong of missing?
