Savin MP 2352sp Email Issue
  • slamanna212
    • Jan 2013
    • 14
    Im at a client that has 2 Savin MP 2352's, both set up to scan to email addresses. 1 is working, 1 is not. It is not an exchange server its a pop3/smtp server from a company called Network Solutions.The settings are exactly the same on every screen except IP address. This is all i see in the system log
    #[dcs_nas(117)]13/03/19 08:24:44 SMTPC: received error code. [503] (202) ERR:
    #[dcs_nas(117)]13/03/19 08:24:44 SMTPC: connection closed. (801) ERR:
    #[dcs_nas(117)]13/03/19 08:38:50 SMTPC: received error code. [503] (202) ERR:
    #[dcs_nas(117)]13/03/19 08:38:50 SMTPC: connection closed. (801) ERR:
  • slamanna212
    • Jan 2013
    • 14
    Re: Savin MP 2352sp Email Issue
    If those errors are SMTP error codes i found this:
    Ever wondered why your emails don’t send or your email marketing campaign fails and all you’re left with is something called an SMTP error code and a short meaningless message?
    503 - The server has encountered a bad sequence of commands.
    • rsyarcia
      Hair Straightener Tech
      • 711
      Have you tried using the Ip Address of the working machine to the other one. Encountered this with a customer and it was An IP and port ISSUE. We isolated it by using the port(Where the Ok machine is connected) and IP.
      Nobody is perfect..
      • slamanna212
        • Jan 2013
        • 14
        I wanted to use IP address from the start but i was told by their IT service that it changes so I have to use Hostname for all machines. If it maters they also have a c9120 that scanning is also working on. The one MP 2352 is the only one that isnt.
        Im updating firmware as i type this to see if that helps.
        • rthonpm
          • Aug 2007
          • 2859
          Is DNS set correctly on the device that's not working? From the op panel, when you enter the mail server name does a communication test work?
          • rsyarcia
            • 711
            Ok.
            Nobody is perfect..
            • slamanna212
              • Jan 2013
              • 14
              Everything was set correctly. No idea how but the user turned off SMTP auth. Turned it back on and it worked.
