Fax Memory Full
  • Rijoh
    • Mar 2011
    • 16
    Fax Memory Full
    Customer has a new MP301 (little desktop piece of junk) with fax forwarding enabled and now all of the incoming faxes have somehow routed to the machine's fax memory and is now full.
    So how do I clear or alleviate the faxes so they print out or just blow them away.
    On the older gen Web Image monitor you could go to the main login page and click on "Fax Receive File" and delete it but the new gen Web Image Monitor doesn't have it or at least I cant find it.
    I called Ricoh Help desk and they were of no help and none of my other sources knew what to do either.
    Anyone? anyone?.......Buhler? Buhler?
    MCSE
  • sandmanmac
    • 3981
    Re: Fax Memory Full
    Although I've never laid my hands on one of these, it sounds that although it is set to forward docs, it is also set to "store" them. I found the following in Ricoh's knowledge base. I think you'll find the answer in the links contained in it:
    Reception File Settings
    • JustManuals
      • Jan 2006
      • 9838
      Re: Fax Memory Full
      RTFM!
      • Athlontini
        • Jun 2012
        • 269
        Re: Fax Memory Full
        In Fax SP just go to category "RAM Clear" and do "Initialize SRAM" and/or "Erase All Files" to clear out what's presently in there.
        • hillclimber
          Re: Fax Memory Full
          I agree with Athlontini that will take care of it.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Re: Fax Memory Full
            The "Fax Receive File" option will only be present if the machine has the optional hard drive.
            Like Paul said, RTFM. The info is all there.
            Hint: Sometimes you have to read the user manual and /or the PSG (Product Support Guide) too.
            “I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.†- Tim Hawkins
            • knightfall
              • Jul 2006
              • 633
              Re: Fax Memory Full
              this will only resolve your problems until the memory is filled up again like Paul said read the manual. There is a reason why its filling up the memory, check where its foward to and why its not working.
              Get your facts first, and then you can distort them as much as you please.
              • Rijoh
                • Mar 2011
                • 16
                Re: Fax Memory Full
                Originally posted by JustManuals.com
                RTFM!
                I hope you get jammed up with MP4001 PM's until the next millennium
                MCSE
                • Rijoh
                  • Mar 2011
                  • 16
                  Re: Fax Memory Full
                  I would never respond to question like that.
                  I'm glad you are not on my team
                  MCSE
                  • Athlontini
                    • Jun 2012
                    • 269
                    Re: Fax Memory Full
                    Ooh, that's harsh.
                    • knightfall
                      • Jul 2006
                      • 633
                      Re: Fax Memory Full
                      such language, this is a family channel. lol
                      • Jomama46
                        • 2900
                        Re: Fax Memory Full
                        Then it begs the question, why are you here?
                        sigpic
                        A+; Network +; PDI+
                        • Ramón
                          • Mar 2011
                          • 26
                          Re: Fax Memory Full
                          You can choose from different types of fax reception and one of them is forward and store. It is quite possible that you have selected this mode. Before you can configure forwarding and storing only have to delete all your stored fax because otherwise you will not let you change the setting.
                          Test and we mention.
                          Regards.
