MPC 3000
  • staffie man
    • Aug 2011
    • 59
    [CQ] MPC 3000
    Hi all
    On A4 paper feeding LEF on single copies colour & mono the copy is faint sometimes totally blank except for a line of print along bottom of copy (short edge),the fault is intermittent sometimes they are fine,any advice greatly appreciated,thanks in advance.
  • Imprestik
    • Aug 2012
    • 296
    Re: MPC 3000
    Hey,
    I will presume all the all the PCU and dev units are within their life along with the transfer unit.
    If so, remove the laser unit and take the shutter off it completely, but leave the hinges that operate the shutter. I have found they warp over time and leave weird copy quality issues.
    • fbkhan3
      • May 2012
      • 421
      Re: MPC 3000
      As you said it's intermittent and for both Mono and color then it should be ITB or ITB's connection terminal's,or broken transfer roller brackets for sure.
      Happy hunting .
      • Eric1968
        • 2458
        Re: MPC 3000
        Before you're going to replace/adjust/clean laser units and pcu's, just one important question : Does it only happen with copies, or also with prints?
        If it only happens with copying checking the optics is the first thing to do.
        • Jimbo1
          • Mar 2008
          • 845
          Re: MPC 3000
          I feel the need to ask a stupid question.
          Is the paper fresh?
          "Some days you get the bear, some days the bear gets you."
          Cdr. William Riker
          • JustManuals
            • Jan 2006
            • 9838
            Re: MPC 3000
            Paul@justmanuals.com
            • staffie man
              • Aug 2011
              • 59
              Re: MPC 3000
              Thanks for the feedback guys,I visited the m/c on my road home last night, it is in an extremely cold enviroment(church).I checked optics,transfer belt & roller,all seemed fine (fault is on prints & copies) I advised customer to keep room on a low heat and if this does not work will do as advised with laser unit,the crazy thing is after half an hour of the m/c being on it started working fine and continued to do so.Thanks again.
